sounds like your valve cover is leaking. You'll need a good mirror on an extension and a flashlight, take the mirror down the backside of the motor from the top and shine the light down at the mirror your leak is probably coming from the back of the valve covers. Repeated boost leak tests and age can cause these leaks. A Nissan shop charges 10 hrs per side so do them yourself. Good luck
